Einleitung
If your LG Risio front-facing camera is not functioning, use this guide to replace it.
Was du brauchst
Use a plastic opening tool to seperate the back panel from the device.
Remove the back panel.
Place your thumb along the bottom of the battery and pry upwards to remove.
Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
Unclip the front camera connector from the motherboard and lift it from the frame.
