Zum Hauptinhalt wechseln
LG Risio Motherboard Replacement
Was du brauchst
  1. LG Risio Motherboard Replacement, Back Panel: Schritt 1, Bild 1 von 2 LG Risio Motherboard Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Use a plastic opening tool to seperate the back panel from the device.
    • Remove the back panel.
  2. LG Risio Motherboard Replacement, Battery: Schritt 2, Bild 1 von 1
    • Place your thumb along the bottom of the battery and pry upwards to remove.
  3. LG Risio Motherboard Replacement, Midframe: Schritt 3, Bild 1 von 1
    • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
  4. LG Risio Motherboard Replacement: Schritt 4, Bild 1 von 2 LG Risio Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Remove the eight Phillips #0 screws from the internal support frame.
  5. LG Risio Motherboard Replacement: Schritt 5, Bild 1 von 3 LG Risio Motherboard Replacement: Schritt 5, Bild 2 von 3 LG Risio Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
  6. LG Risio Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Using your hand, pick up the midframe to separate it from the phone.
  7. LG Risio Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 2 LG Risio Motherboard Replacement, Motherboard: Schritt 7, Bild 2 von 2
    • Detach the screen connector from the motherboard by putting your thumb underneath it and lifting up.
    • The screen connector is the part that has P5 written on it.
  8. LG Risio Motherboard Replacement: Schritt 8, Bild 1 von 1
    • On the side with the screen connector, pull the two tabs away from the device.
    • Use the plastic opening tool to lift the motherboard starting on the bottom right corner and pulling upwards.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 261
