Zum Hauptinhalt wechseln
Einleitung
If the rear-facing camera is taking photos that are blurry, replacing the camera may fix that issue. Use this guide to replace the rear-facing camera.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use a plastic opening tool to seperate the back panel from the device. Remove the back panel.
    • Use a plastic opening tool to seperate the back panel from the device.
    • Remove the back panel.
  2. Place your thumb along the bottom of the battery and pry upwards to remove.
    • Place your thumb along the bottom of the battery and pry upwards to remove.
  3. Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
    • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
  4. Remove the eight Phillips #0 screws from the internal support frame. Remove the eight Phillips #0 screws from the internal support frame.
    • Remove the eight Phillips #0 screws from the internal support frame.
  5. Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up. Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up. Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
    • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
  6. Using your hand, pick up the midframe to  separate it from the phone.
    • Using your hand, pick up the midframe to separate it from the phone.
    • If the midframe does not want to lift off, go back and repeat step 6.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 79
