Einleitung
If your phone is switching off while in use or if it doesn't hold a charge anymore then the battery may need to be replaced. This guide takes you through the necessary steps to accomplish this.
Was du brauchst
Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
