Zum Hauptinhalt wechseln
Einleitung
If you are having issues with your motherboard, such as the blue screen of death, constant errors, or crashes you may need to replace the motherboard. This guide will take you through the necessary steps to replace the Motherboard.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone. Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
    • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
  2. Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
    • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
  3. Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver. Use the magnetic mat to keep the screws in one place.
    • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
    • Use the magnetic mat to keep the screws in one place.
  4. Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
    • Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
  5. Detach the black rectangular film attached to the SIM/SD card plate with a plastic opening tool.
    • Detach the black rectangular film attached to the SIM/SD card plate with a plastic opening tool.
  6. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  7. Hook the plastic opening tool underneath the plate and gently lift it up.
    • Hook the plastic opening tool underneath the plate and gently lift it up.
  8. Gently wiggle the plate side-to-side while pulling up to release it from the metal clamps holding it in.
    • Gently wiggle the plate side-to-side while pulling up to release it from the metal clamps holding it in.
  9. Use the plastic opening tool to lift up the connector that holds the camera to the board. Use the plastic opening tool to lift up the connector that holds the camera to the board.
    • Use the plastic opening tool to lift up the connector that holds the camera to the board.
  10. Pull the camera gently out of its housing in the motherboard with your fingers.
    • Pull the camera gently out of its housing in the motherboard with your fingers.
  11. Using the plastic opening tool, gently pry up the audio port connector. Using the plastic opening tool, gently pry up the audio port connector.
    • Using the plastic opening tool, gently pry up the audio port connector.
  12. Remove the audio port from the motherboard with either your hand or the plastic opening tool.
    • Remove the audio port from the motherboard with either your hand or the plastic opening tool.
  13. Detach the two cable connector wires from the motherboard with the plastic opening tool. Detach the remaining five connectors from the phone with the plastic opening tool.
    • Detach the two cable connector wires from the motherboard with the plastic opening tool.
    • Detach the remaining five connectors from the phone with the plastic opening tool.
  14. Hook the plastic opening tool underneath the motherboard and firmly lift it out of the phone casing. Hook the plastic opening tool underneath the motherboard and firmly lift it out of the phone casing.
    • Hook the plastic opening tool underneath the motherboard and firmly lift it out of the phone casing.
Abschluss
Aiman Sallam
506 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 1-4, Sullivan Spring 2016 Mitglied von USF Tampa, Team 1-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G4
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 403
