Einleitung
If the display on the phone is cracked or is unresponsive to touch in areas or the whole phone you may need to replace the display. This will require you to take everything out of the phone as the display itself cannot be removed solely without possible damage to other parts of the phone.
  1. First you need to remove the back case of the phone. Place the phone face down. Using the plastic opening tool, insert into the initial gap shown.
    • First you need to remove the back case of the phone.
    • Place the phone face down.
    • Using the plastic opening tool, insert into the initial gap shown.
    • Slowly guide the tool around the case until the case comes off with ease.
  2. Place the back case to the side. Use your finger or the opening tool to remove battery. Remove the battery carefully to not damage the phone or the battery.
    • Place the back case to the side.
    • Use your finger or the opening tool to remove battery.
    • Remove the battery carefully to not damage the phone or the battery.
  3. Remove the eleven 4mm Phillips #00 screws. Place screws in safe location. Use Plastic opener tool to remove inner case.
    • Remove the eleven 4mm Phillips #00 screws.
    • Place screws in safe location.
    • Use Plastic opener tool to remove inner case.
    • Gently remove inner case.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Use your finger or the opener to flip the flex cable shown in red box. Use the precision tweezers to remove camera carefully. Use the precision tweezers to remove camera carefully.
    • Use your finger or the opener to flip the flex cable shown in red box.
    • Use the precision tweezers to remove camera carefully.
  6. Gently flip the cables(shown in red boxes) using the opener tool. Gently remove the motherboard itself. Place motherboard on a soft surface to not damage it.
    • Gently flip the cables(shown in red boxes) using the opener tool.
    • Gently remove the motherboard itself.
    • Place motherboard on a soft surface to not damage it.
  7. Carefully remove the Vibrator. Carefully remove the sensor. Prepare to remove film.
    • Carefully remove the Vibrator.
    • Carefully remove the sensor.
    • Prepare to remove film.
  8. Use the tweezers to peel the film off carefully. Use the tweezers to remove the headphone jack gently. Place all three devices in a safe, known, location.
    • Use the tweezers to peel the film off carefully.
    • Use the tweezers to remove the headphone jack gently.
    • Place all three devices in a safe, known, location.
Abschluss
8 weitere Nutzer haben diese Anleitung absolviert.
Devon Barber
775 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S11-G1, Cheng Spring 2018 Mitglied von USF Tampa, Team S11-G1, Cheng Spring 2018
USFT-CHENG-S18S11G1
4 Mitglieder
Hello guys
I just replaced the screen for my LG Stylus 2 plus. I got the display off https://www.injuredgadgets.com/lg-stylus...
But after replacing the screen and turning it on only the back light is functioning. I tried reusing the old display and it worked just fine. Is there any suggestions to why this one is not working or is my new screen just a bust ?
Several Genie - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 15
Letzte 7 Tage: 63
Letzte 30 Tage: 223
Insgesamt: 2,085
