Zum Hauptinhalt wechseln
LG Stylo 2 Motherboard Replacement
Was du brauchst
  1. LG Stylo 2 Motherboard  Replacement, Battery: Schritt 1, Bild 1 von 3 LG Stylo 2 Motherboard  Replacement, Battery: Schritt 1, Bild 2 von 3 LG Stylo 2 Motherboard  Replacement, Battery: Schritt 1, Bild 3 von 3
    • First you need to remove the back case of the phone.
    • Place the phone face down.
    • Using the plastic opening tool, insert into the initial gap shown.
    • Slowly guide the tool around the case until the case comes off with ease.
  2. LG Stylo 2 Motherboard  Replacement: Schritt 2, Bild 1 von 3 LG Stylo 2 Motherboard  Replacement: Schritt 2, Bild 2 von 3 LG Stylo 2 Motherboard  Replacement: Schritt 2, Bild 3 von 3
    • Place the back case to the side.
    • Use your finger or the opening tool to remove battery.
    • Remove the battery carefully to not damage the phone or the battery.
  3. LG Stylo 2 Motherboard  Replacement, Rear Camera: Schritt 3, Bild 1 von 3 LG Stylo 2 Motherboard  Replacement, Rear Camera: Schritt 3, Bild 2 von 3 LG Stylo 2 Motherboard  Replacement, Rear Camera: Schritt 3, Bild 3 von 3
    • Remove the eleven 4mm Phillips #00 screws.
    • Place screws in safe location.
    • Use Plastic opener tool to remove inner case.
    • Gently remove inner case.
  4. LG Stylo 2 Motherboard  Replacement: Schritt 4, Bild 1 von 3 LG Stylo 2 Motherboard  Replacement: Schritt 4, Bild 2 von 3 LG Stylo 2 Motherboard  Replacement: Schritt 4, Bild 3 von 3
    • Use your finger or the opener to flip the flex cable shown in red box.
    • Use the precision tweezers to remove camera carefully.
  5. LG Stylo 2 Motherboard  Replacement, Motherboard: Schritt 5, Bild 1 von 3 LG Stylo 2 Motherboard  Replacement, Motherboard: Schritt 5, Bild 2 von 3 LG Stylo 2 Motherboard  Replacement, Motherboard: Schritt 5, Bild 3 von 3
    • Gently flip the cables(shown in red boxes) using the opener tool.
    • Gently remove the motherboard itself.
    • Place motherboard on a soft surface to not damage it.
Abschluss
Devon Barber
994 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S11-G1, Cheng Spring 2018 Mitglied von USF Tampa, Team S11-G1, Cheng Spring 2018
USFT-CHENG-S18S11G1
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Charging retain 2.1
Kashif Kashi - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 2,224
