Zum Hauptinhalt wechseln
LG Stylo 2 Plus Speaker Replacement
Was du brauchst
  1. LG Stylo 2 Plus Speaker Replacement, Rear Case: Schritt 1, Bild 1 von 3 LG Stylo 2 Plus Speaker Replacement, Rear Case: Schritt 1, Bild 2 von 3 LG Stylo 2 Plus Speaker Replacement, Rear Case: Schritt 1, Bild 3 von 3
    • To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
    • With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
  2. LG Stylo 2 Plus Speaker Replacement, Battery: Schritt 2, Bild 1 von 3 LG Stylo 2 Plus Speaker Replacement, Battery: Schritt 2, Bild 2 von 3 LG Stylo 2 Plus Speaker Replacement, Battery: Schritt 2, Bild 3 von 3
    • To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
    • Firmly grasp the battery and remove from the phone.
  3. LG Stylo 2 Plus Speaker Replacement, Speaker: Schritt 3, Bild 1 von 2 LG Stylo 2 Plus Speaker Replacement, Speaker: Schritt 3, Bild 2 von 2
    • Remove the cover from the phone in order to access the speaker.
    • Using the JIS #000 screwdriver, remove the four 4mm screws around the base of the mid-frame.
  4. LG Stylo 2 Plus Speaker Replacement: Schritt 4, Bild 1 von 2 LG Stylo 2 Plus Speaker Replacement: Schritt 4, Bild 2 von 2
    • Insert the metal spudger in the dimple at the base of the mid-frame.
    • Pry upward, removing bottom section of the mid-frame from the phone.
  5. LG Stylo 2 Plus Speaker Replacement: Schritt 5, Bild 1 von 3 LG Stylo 2 Plus Speaker Replacement: Schritt 5, Bild 2 von 3 LG Stylo 2 Plus Speaker Replacement: Schritt 5, Bild 3 von 3
    • Flip the bottom piece of the mid-frame over to show the speaker in the bottom right corner.
    • Using the tweezers, peel back the rubber resting on top of the speaker.
    • Still using the tweezers, grasp the speaker unit and remove it from the mid-frame.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Noah Kehm
241 Reputation
3 Anleitungen geschrieben
UW Tacoma, Team S1-G3, Cardinal Spring 2019 Mitglied von UW Tacoma, Team S1-G3, Cardinal Spring 2019
UWT-CARDINAL-S19S1G3
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 467
