Zum Hauptinhalt wechseln
Einleitung
If your phone's selfie camera is failing to take pictures, it may be time to replace the front camera. This guide will take you step by step on how to replace the camera of your LG Stylo 3 Plus in about 5 minutes.
  1. Power off the phone before beginning disassembly. Place the phone face down. Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
    • Power off the phone before beginning disassembly.
    • Place the phone face down.
    • Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
    • Carefully slide your finger or the tool throughout the edge of the phone to ease the back case off.
  2. Place the back cover off to the side. Insert the opening tool into the small gap below the battery. Carefully pop the battery out to prevent damage.
    • Place the back cover off to the side.
    • Insert the opening tool into the small gap below the battery.
    • Carefully pop the battery out to prevent damage.
  3. Remove the twelve 4mm screws using the Phillips #000 screwdriver. Use the plastic opening tool to remove the inner case. Carefully remove the inner case.
    • Remove the twelve 4mm screws using the Phillips #000 screwdriver.
    • Use the plastic opening tool to remove the inner case.
    • Carefully remove the inner case.
  4. Use your fingernail or the plastic opening tool to flip the flex cable. Use the precision tweezers to carefully grasp and pull out the camera.
    • Use your fingernail or the plastic opening tool to flip the flex cable.
    • Use the precision tweezers to carefully grasp and pull out the camera.
  5. Carefully flip open the flex cable box with the plastic opening tool. Using precision tweezers, carefully lift the front camera off the device.
    • Carefully flip open the flex cable box with the plastic opening tool.
    • Using precision tweezers, carefully lift the front camera off the device.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Patricia Pires Dias
594 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S2-G6, Peak Fall 2018 Mitglied von UMass Dartmouth, Team S2-G6, Peak Fall 2018
UMASSD-PEAK-F18S2G6
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 13
Insgesamt: 314
