Einleitung
Use this guide to replace the motherboard of your LG Stylo 3 Plus.
Was du brauchst
Place the phone face down.
Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
Carefully slide your finger or the tool throughout the edge of the phone to ease the back case off.
Place the back cover off to the side.
Insert the opening tool into the small gap below the battery.
Carefully pop the battery out to prevent damage.
Remove the twelve 4mm screws using the Phillips #000 screwdriver.
Use the plastic opening tool to remove the inner case.
Carefully remove the inner case.
Use your fingernail or the plastic opening tool to flip the flex cable.
Use the precision tweezers to carefully grasp and pull out the camera.
Carefully flip open the flex cable box with the plastic opening tool.
Using precision tweezers, carefully lift the front camera off the device.
Gently flip open the flex cable box using a blue plastic opening tool.
Carefully remove the motherboard with your hands or a blue plastic opening tool.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
