Einleitung
This guide will walk you through the steps of removing the midframe of your LG Sunrise.
Was du brauchst
Use a prying tool or a flat head screwdriver to pry the back cover from the device.
Schritt 5 Lower Back Plastic Piece
Achtung: Die Schritte 5-6 stammen von einer Anleitung, die derzeit bearbeitet wird.
You will be first removing the two lower screws. This is allow you to remove the lower plastic piece.
Once you have removed all 6 screws. Gently pry all sides of back plastic piece, starting at the bottom. Once you start on the bottom, it will become easier to pry.
Once you have pried off the back piece, the mother board should be exposed. Set this piece aside for replacement or reassembly.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
