Einleitung
This guide provides instructions for replacing the microphone on the LG TP 1100 flip phone.
Was du brauchst
Hold antenna between your fingers and unscrew in a counterclockwise direction.
You will remove antenna by pulling it in an upward motion away from the socket.
Hold phone securely in one hand and pull the battery away from the phone with your other hand.
Rotate the phone so that the circuit board is in the palm of your hand and the part connected with tape hangs behind.
Use your opening tool to pry the circuit board from the front cover. Do not let the number pad to fall out.
To remove the microphone, insert your opening tool under microphone and push upward to pry microphone away from the front cover.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
