Zum Hauptinhalt wechseln
LG TP 1100 Microphone Replacement
Was du brauchst
  1. LG TP 1100 Microphone Replacement, Microphone: Schritt 1, Bild 1 von 1
    • Hold antenna between your fingers and unscrew in a counterclockwise direction.
  2. LG TP 1100 Microphone Replacement: Schritt 2, Bild 1 von 1
    • You will remove antenna by pulling it in an upward motion away from the socket.
  3. LG TP 1100 Microphone Replacement: Schritt 3, Bild 1 von 1
    • Turn phone so that the back is facing you.
  4. LG TP 1100 Microphone Replacement: Schritt 4, Bild 1 von 1
    • Use your thumb to pull the tab in an upward motion to release the battery.
  5. LG TP 1100 Microphone Replacement: Schritt 5, Bild 1 von 1
    • Hold phone securely in one hand and pull the battery away from the phone with your other hand.
  6. LG TP 1100 Microphone Replacement: Schritt 6, Bild 1 von 1
    • Use your screwdriver to unscrew the four screws from the back plate.
  7. LG TP 1100 Microphone Replacement: Schritt 7, Bild 1 von 1
    • Turn phone to the side as indicated in the picture.
  8. LG TP 1100 Microphone Replacement: Schritt 8, Bild 1 von 1
    • Remove the back cover that you just unscrewed and set aside.
  9. LG TP 1100 Microphone Replacement: Schritt 9, Bild 1 von 1
    • Open the remaining parts like a book but do not separate the two pieces.
    • Do not tear the tape connecting the two pieces.
  10. LG TP 1100 Microphone Replacement: Schritt 10, Bild 1 von 2 LG TP 1100 Microphone Replacement: Schritt 10, Bild 2 von 2
    • Rotate the phone so that the circuit board is in the palm of your hand and the part connected with tape hangs behind.
    • Use your opening tool to pry the circuit board from the front cover. Do not let the number pad to fall out.
  11. LG TP 1100 Microphone Replacement: Schritt 11, Bild 1 von 1
    • To remove the microphone, insert your opening tool under microphone and push upward to pry microphone away from the front cover.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Johnny Inlow
19 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 27-91, Amido Spring 2010 Mitglied von Cal Poly, Team 27-91, Amido Spring 2010
CPSU-AMIDO-S10S27G91
5 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,289
