Zum Hauptinhalt wechseln
LG Thrill 4G Phone Buttons Replacement
Was du brauchst
  1. LG Thrill 4G Phone Buttons Replacement, Back Cover Removal: Schritt 1, Bild 1 von 2 LG Thrill 4G Phone Buttons Replacement, Back Cover Removal: Schritt 1, Bild 2 von 2
    • Pry open the back cover by using a fingernail or a plastic opening tool.
    • There is a small notch at the bottom of the cover for easy removal.
  2. LG Thrill 4G Phone Buttons Replacement, Battery Removal: Schritt 2, Bild 1 von 2 LG Thrill 4G Phone Buttons Replacement, Battery Removal: Schritt 2, Bild 2 von 2
    • Remove the battery from the phone.
    • There is a small ledge located at the bottom of the battery for easy removal.
  3. LG Thrill 4G Phone Buttons Replacement, Screw Removal: Schritt 3, Bild 1 von 1
    • Remove the three Philips #00 screws from the bottom of the phone.
    • Two 5.5 mm screws
    • One 4 mm screw
  4. LG Thrill 4G Phone Buttons Replacement, Speaker Removal: Schritt 4, Bild 1 von 2 LG Thrill 4G Phone Buttons Replacement, Speaker Removal: Schritt 4, Bild 2 von 2
    • Use your finger or opening tool to wedge the speaker out starting at the small notch at the bottom of the phone.
  5. LG Thrill 4G Phone Buttons Replacement, Buttons: Schritt 5, Bild 1 von 1
    • Remove the three buttons from the side and the top of the phone.
    • Power button
    • Volume button
    • 3D camera button
  6. LG Thrill 4G Phone Buttons Replacement: Schritt 6, Bild 1 von 3 LG Thrill 4G Phone Buttons Replacement: Schritt 6, Bild 2 von 3 LG Thrill 4G Phone Buttons Replacement: Schritt 6, Bild 3 von 3
    • Place the plastic opening tool under the bezel at either bottom corner of the HDMI cover.
    • This loosens both the HDMI and USB covers for easy removal.
    • USB Cover
    • HDMI Cover
  7. LG Thrill 4G Phone Buttons Replacement: Schritt 7, Bild 1 von 1
    • Remove the six Phillips #00 screws within the mid-cover bezel.
Abschluss
USF Tampa, Team 1-6, Blackwell Winter 2015 Mitglied von USF Tampa, Team 1-6, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 546
