Zum Hauptinhalt wechseln
LG Tone Active HBS-850 Speaker Replacement
Was du brauchst
  1. LG Tone Active HBS-850 Speaker Replacement, Locate Hidden Screw: Schritt 1, Bild 1 von 2 LG Tone Active HBS-850 Speaker Replacement, Locate Hidden Screw: Schritt 1, Bild 2 von 2
    • Locate the hidden screw as seen in the picture and remove the rubber covering the screw.
  2. LG Tone Active HBS-850 Speaker Replacement, Remove Hidden Screw: Schritt 2, Bild 1 von 1
    • Remove hidden screw using a Philips #00 screwdriver.
  3. LG Tone Active HBS-850 Speaker Replacement, Pry Open Speaker Housing: Schritt 3, Bild 1 von 2 LG Tone Active HBS-850 Speaker Replacement, Pry Open Speaker Housing: Schritt 3, Bild 2 von 2
    • Use a guitar pick or any pry opening tool to gently lift the housing until the speaker end. There is a hidden screw that needs to be removed before the housing can be completely removed.
  4. LG Tone Active HBS-850 Speaker Replacement, Locate Hidden Speaker Screw: Schritt 4, Bild 1 von 2 LG Tone Active HBS-850 Speaker Replacement, Locate Hidden Speaker Screw: Schritt 4, Bild 2 von 2
    • Gently remove the pointy rubber covering using tweezers where the speaker rests as shown in the picture.
  5. LG Tone Active HBS-850 Speaker Replacement, Remove Hidden Speaker Screw: Schritt 5, Bild 1 von 2 LG Tone Active HBS-850 Speaker Replacement, Remove Hidden Speaker Screw: Schritt 5, Bild 2 von 2
    • Use a Philips #00 screwdriver to remove the hidden screw.
  6. LG Tone Active HBS-850 Speaker Replacement, Remove Speaker Screw: Schritt 6, Bild 1 von 1
    • Remove the screw holding the speaker in place using a Philips #00 screwdriver.
  7. LG Tone Active HBS-850 Speaker Replacement, Desolder Speaker: Schritt 7, Bild 1 von 2 LG Tone Active HBS-850 Speaker Replacement, Desolder Speaker: Schritt 7, Bild 2 von 2
    • Desolder speaker connection using a soldering iron and replace with new speaker.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Faizan Naveed
3.294 Reputation
8 Anleitungen geschrieben
Mobile Device Repair Factory Mitglied von Mobile Device Repair Factory
Business
1 Mitglied
16 Anleitungen geschrieben
4 Kommentare
Do you know of a place to buy a replacement speaker?
James Cimabue - Antwort
Excellent instructions and thank you for your time doing this! Can you give a source for the speaker parts other than LG ?
Again thank you
Jim Husselman - Antwort
BT Headphone Neckband type with Retractable Earbud (similar contruction ) :: Do you have instructions for repairing loose connection between earbud and wire for model SX-991
Rajesh Narayanan - Antwort
Cant find anywhere to buy replacement speakers!
tom - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 11
Insgesamt: 2,536
