Was du brauchst
Find the side of the device with the defective magnet. Remove the rubber piece on the underside of the device that protects the screw.
Place a small prying tool in between the two cases and slowly push the two apart. Be sure not to force the case apart, as it may snap in the process.
The small screw that was taken out at the beginning can be screwed back into the device.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
