Zum Hauptinhalt wechseln
Einleitung
This guide will explain how to replace the Auxiliary Port (headphone jack) on the LG Treasure.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Make sure the LG Treasure is turned off. Pull off the back cover from the phone using the groove on the bottom right side.
    • Make sure the LG Treasure is turned off.
    • Pull off the back cover from the phone using the groove on the bottom right side.
  2. Remove the battery from the phone by lifting up on the bottom end of the battery.
    • Remove the battery from the phone by lifting up on the bottom end of the battery.
  3. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Jetzt kaufen
    iPhone X Fix Kits
    Jetzt kaufen
  4. Remove all 9 of the 3mm Phillips #000 screws from the digitizer. Work your way around the edge of the phone, gently prying the digitizer off the phone.
    • Remove all 9 of the 3mm Phillips #000 screws from the digitizer.
    • Work your way around the edge of the phone, gently prying the digitizer off the phone.
  5. Insert your finger nail into the groove under the Auxiliary Port and pry the Auxiliary Port out. Insert your finger nail into the groove under the Auxiliary Port and pry the Auxiliary Port out. Insert your finger nail into the groove under the Auxiliary Port and pry the Auxiliary Port out.
    • Insert your finger nail into the groove under the Auxiliary Port and pry the Auxiliary Port out.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
david amirahmadi
537 Reputation
5 Anleitungen geschrieben
UW Stout, Team S8-G5, Ogden Spring 2018 Mitglied von UW Stout, Team S8-G5, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G5
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 118
