Einleitung
This guide will explain how to replace the rear camera on the LG Treasure.
Was du brauchst
Pull off the back cover from the phone using the groove on the bottom right side.
Remove the battery from the phone by lifting up on the bottom end of the battery.
Remove all 9 of the 3 mm Phillips #000 screws from the digitizer.
Work your way around the edge of the phone, gently prying the digitizer off the phone.
Pull up on the gold film-like connector which is to the left side of camera. Once you have pulled the connector loose you can then gently lift the rear camera out of the phone.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
