Einleitung
This guide will show you how to replace the battery in your LG Tribute 5, model LS675. If your phone does not hold a charge, it might be a faulty battery. Replacing your phone’s battery will fix this issue.
Was du brauchst
Using an iFixit opening tool, gently pull outward on the cutout on the bottom left corner of the phone to remove the back cover.
Gently lift the battery out from the compartment.
Use an iFixit opening tool to slide out the SD card and nano sim card from the device as shown.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
