Zum Hauptinhalt wechseln
LG Tribute 5 Motherboard Replacement
Was du brauchst
  1. LG Tribute 5 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 LG Tribute 5 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Using an iFixit opening tool, gently pull outward on the cutout on the bottom left corner of the phone to remove the back cover.
  2. LG Tribute 5 Motherboard Replacement: Schritt 2, Bild 1 von 3 LG Tribute 5 Motherboard Replacement: Schritt 2, Bild 2 von 3 LG Tribute 5 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Gently lift the battery out from the compartment.
    • Use an iFixit opening tool to slide out the SD card and nano sim card from the device as shown.
  3. LG Tribute 5 Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 3 LG Tribute 5 Motherboard Replacement, Motherboard: Schritt 3, Bild 2 von 3 LG Tribute 5 Motherboard Replacement, Motherboard: Schritt 3, Bild 3 von 3
    • Remove the nine 2mm JIS #00 screws from the mid-frame.
  4. LG Tribute 5 Motherboard Replacement: Schritt 4, Bild 1 von 3 LG Tribute 5 Motherboard Replacement: Schritt 4, Bild 2 von 3 LG Tribute 5 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Using an iFixit opening tool, remove the antenna extender located at the bottom.
  5. LG Tribute 5 Motherboard Replacement: Schritt 5, Bild 1 von 2 LG Tribute 5 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Gently remove the mid-frame using an iFixit opening tool as shown.
    • Avoid applying too much force when separating the mid frame. Too much force can bend or damage the device.
  6. LG Tribute 5 Motherboard Replacement: Schritt 6, Bild 1 von 2 LG Tribute 5 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Using an iFixit opening tool, gently disconnect the rear camera from the top center of the motherboard.
    • Remove the front facing camera from the top right corner of the motherboard.
  7. LG Tribute 5 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Gently pull the speaker out from its compartment with the iFixit opening tool.
  8. LG Tribute 5 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Disconnect the flex cable from the motherboard with the iFixit opening tool.
  9. LG Tribute 5 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Gently pull up and remove the motherboard using the iFixit opening tool.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
UW Tacoma, Team S1-G6, Cardinal Spring 2019 Mitglied von UW Tacoma, Team S1-G6, Cardinal Spring 2019
UWT-CARDINAL-S19S1G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 388
