Einleitung
This guide will teach you how to properly replace the front facing camera in the phone.
Was du brauchst
Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
Use the plastic opening tool to carefully pry the front-facing camera from the motherboard.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
