Einleitung
In this guide we will teach you how to properly remove and replace the LG Tribute HD's volume and power buttons
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
    • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
  2. Pull the battery out of the phone.
    • Pull the battery out of the phone.
    • Remove the SD Card by sliding the card out as shown.
    • Remove the twelve 2mm JIS #00 screws from the mid-frame.
    • Using a plastic opening tool, remove the antenna extender from the mid-frame.
    • Using your fingers, remove the mid-frame.
    • Use a plastic opening tool to remove the buttons by pushing them in until they pop through.
Abschluss
Dhruv Patel
Mitglied seit 14.02.2018
265 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S1-G3, Nance Spring 2018 Mitglied von USF Tampa, Team S1-G3, Nance Spring 2018
USFT-NANCE-S18S1G3
4 Mitglieder
10 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 223
