Einleitung
This guide will teach you how to properly replace the LCD screen and touch digitizer with frame. Precaution should be taken if handling a cracked screen to avoid cuts from broken glass. This repair may be needed if the screen is unresponsive to touch or the screen has been damaged or cracked.
  1. Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
    • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
  2. Pull the battery out of the phone.
    • Pull the battery out of the phone.
    • Remove the SD Card by sliding the card out as shown.
    • Remove the twelve 2mm JIS #00 screws from the mid-frame.
    • Using a plastic opening tool, remove the antenna extender from the bottom.
    • Using your fingers, remove the mid-frame.
    • Use a plastic opening tool to disconnect the front and rear cameras from the motherboard.
    • Remove the cameras from the phone.
    • Using a plastic opening tool, pry up the front facing speaker and remove it from the phone.
    • Disconnect the LCD from the motherboard with a plastic opening tool.
    • Use a plastic opening tool to pry up the motherboard form the display housing.
    • Remove the motherboard from the phone.
    • Use your fingers to remove the flex cables from the phone.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Aalia Mohammed
Mitglied seit 14.02.2018
438 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S1-G3, Nance Spring 2018 Mitglied von USF Tampa, Team S1-G3, Nance Spring 2018
USFT-NANCE-S18S1G3
4 Mitglieder
10 Anleitungen geschrieben
Just a note that the flex cables are stuck pretty well to the case. I didn’t rip them but I used a little heat from a hair dryer to soften the glue a bit.
christophergosnell - Antwort
I somewhat agree with christophergosnell on this one but I did manage to lift up the ribbon cables using both my fingernails and a small, then, flat head screwdriver at just the right points. there is also a ribbon cable near the bottom of the phone that I had to transplant that is shown but you don’t include a picture of you even attempting to remove it. I didn’t pay attention what it connected to but I just made sure it went in the same spot on the new screen assembly. Other then that a pretty decent guide.
Robert Surles - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 6
Letzte 7 Tage: 19
Letzte 30 Tage: 96
Insgesamt: 767
