Einleitung
In this guide we will teach you how to properly remove and replace the flex cable in the LG Tribute HD LS676. The flex cable or cable ribbon is a small delicate cable that is connected to the motherboard. It should be handled cautiously since it can be easily damaged by an applied force.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove. Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
    • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
  2. Pull the battery out of the phone. Remove the SD Card by sliding the card out as shown.
    • Pull the battery out of the phone.
    • Remove the SD Card by sliding the card out as shown.
  3. Remove the twelve 2mm JIS #00 screws from the mid-frame. Remove the twelve 2mm JIS #00 screws from the mid-frame.
    • Remove the twelve 2mm JIS #00 screws from the mid-frame.
  4. Using a plastic opening tool, remove the antenna extender from the bottom. Using a plastic opening tool, remove the antenna extender from the bottom. Using a plastic opening tool, remove the antenna extender from the bottom.
    • Using a plastic opening tool, remove the antenna extender from the bottom.
  5. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Using your fingers, remove the mid-frame. Using your fingers, remove the mid-frame.
    • Using your fingers, remove the mid-frame.
  7. Use a plastic opening tool to disconnect the front and rear cameras from the motherboard. Remove the cameras from the phone. Remove the cameras from the phone.
    • Use a plastic opening tool to disconnect the front and rear cameras from the motherboard.
    • Remove the cameras from the phone.
  8. Using a plastic opening tool, pry up the front facing speaker and remove it from the phone. Using a plastic opening tool, pry up the front facing speaker and remove it from the phone. Using a plastic opening tool, pry up the front facing speaker and remove it from the phone.
    • Using a plastic opening tool, pry up the front facing speaker and remove it from the phone.
  9. Disconnect the LCD from the motherboard with a plastic opening tool.
    • Disconnect the LCD from the motherboard with a plastic opening tool.
  10. Use a plastic opening tool to pry up the motherboard form the display housing. Remove the motherboard from the phone.
    • Use a plastic opening tool to pry up the motherboard form the display housing.
    • Remove the motherboard from the phone.
  11. Use your fingers to remove the flex cables from the phone. Use your fingers to remove the flex cables from the phone.
    • Use your fingers to remove the flex cables from the phone.
Abschluss
Dhruv Patel
268 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S1-G3, Nance Spring 2018 Mitglied von USF Tampa, Team S1-G3, Nance Spring 2018
USFT-NANCE-S18S1G3
4 Mitglieder
10 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 215
