Einleitung
In this guide we will teach you how to properly remove and replace the flex cable in the LG Tribute HD LS676. The flex cable or cable ribbon is a small delicate cable that is connected to the motherboard. It should be handled cautiously since it can be easily damaged by an applied force.
Was du brauchst
Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
Pull the battery out of the phone.
Remove the SD Card by sliding the card out as shown.
Use a plastic opening tool to disconnect the front and rear cameras from the motherboard.
Remove the cameras from the phone.
Using a plastic opening tool, pry up the front facing speaker and remove it from the phone.
Use a plastic opening tool to pry up the motherboard form the display housing.
Remove the motherboard from the phone.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
