Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Einleitung
This guide will teach you how to properly replace the headphones jack in the LG Tribute HD LS676.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove. Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
    • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
  2. Pull the battery out of the phone. Remove the SD Card by sliding the card out as shown.
    • Pull the battery out of the phone.
    • Remove the SD Card by sliding the card out as shown.
  3. Remove the twelve 2mm JIS #00 screws from the mid-frame. Remove the twelve 2mm JIS #00 screws from the mid-frame.
    • Remove the twelve 2mm JIS #00 screws from the mid-frame.
  4. Using a plastic opening tool, remove the antenna extender from the mid-frame. Using a plastic opening tool, remove the antenna extender from the mid-frame. Using a plastic opening tool, remove the antenna extender from the mid-frame.
    • Using a plastic opening tool, remove the antenna extender from the mid-frame.
  5. Using your fingers, remove the mid-frame. Using your fingers, remove the mid-frame.
    • Using your fingers, remove the mid-frame.
  6. Use plastic opening tool to pry up the flex cable from the back panel. Flip over and push on the back side of the headphone jack to dislodge it. Flip over and push on the back side of the headphone jack to dislodge it.
    • Use plastic opening tool to pry up the flex cable from the back panel.
    • Flip over and push on the back side of the headphone jack to dislodge it.
Abschluss
Jerry Koenig
619 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S1-G3, Nance Spring 2018 Mitglied von USF Tampa, Team S1-G3, Nance Spring 2018
USFT-NANCE-S18S1G3
4 Mitglieder
10 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 4
Insgesamt: 349
