Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Einleitung
This guide will teach you how to properly replace the motherboard in the LG Tribute HD LS676. The motherboard is a key component that connects and controls all the other phone components. Caution should be taken when replacing it since it is a delicate component that can be easily damaged. Replacement of the motherboard will result in loss of old data and documents previously stored on the phone. It is recommended to externally back-up any important data from the phone before proceeding to replace the motherboard.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove. Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
    • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
  2. Pull the battery out of the phone. Remove the SD Card by sliding the card out as shown.
    • Pull the battery out of the phone.
    • Remove the SD Card by sliding the card out as shown.
  3. Remove the twelve 2mm JIS #00 screws from the mid-frame. Remove the twelve 2mm JIS #00 screws from the mid-frame.
    • Remove the twelve 2mm JIS #00 screws from the mid-frame.
  4. Using a plastic opening tool, remove the antenna extender from the mid-frame. Using a plastic opening tool, remove the antenna extender from the mid-frame. Using a plastic opening tool, remove the antenna extender from the mid-frame.
    • Using a plastic opening tool, remove the antenna extender from the mid-frame.
  5. Using your fingers, remove the mid-frame. Using your fingers, remove the mid-frame.
    • Using your fingers, remove the mid-frame.
  6. Use a plastic opening tool to disconnect the front and rear cameras from the motherboard and pull out to remove. Use a plastic opening tool to disconnect the front and rear cameras from the motherboard and pull out to remove. Use a plastic opening tool to disconnect the front and rear cameras from the motherboard and pull out to remove.
    • Use a plastic opening tool to disconnect the front and rear cameras from the motherboard and pull out to remove.
  7. Using a plastic opening tool, pry up the front facing speaker and remove from the phone. Using a plastic opening tool, pry up the front facing speaker and remove from the phone. Using a plastic opening tool, pry up the front facing speaker and remove from the phone.
    • Using a plastic opening tool, pry up the front facing speaker and remove from the phone.
  8. Disconnect the display from the motherboard.
    • Disconnect the display from the motherboard.
  9. Use a plastic opening tool to pry up the motherboard and pull out to remove. Use a plastic opening tool to pry up the motherboard and pull out to remove.
    • Use a plastic opening tool to pry up the motherboard and pull out to remove.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Aalia Mohammed
442 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S1-G3, Nance Spring 2018 Mitglied von USF Tampa, Team S1-G3, Nance Spring 2018
USFT-NANCE-S18S1G3
4 Mitglieder
10 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 2
Letzten 7 Tage: 3
Letzten 30 Tage: 17
Insgesamt: 578
