Zum Hauptinhalt wechseln
LG Tribute Rear-Facing Camera Replacement
Was du brauchst
  1. LG Tribute Rear-Facing Camera Replacement, Battery: Schritt 1, Bild 1 von 2 LG Tribute Rear-Facing Camera Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use the plastic opening tool to pry off the back cover.
  2. LG Tribute Rear-Facing Camera Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
  3. LG Tribute Rear-Facing Camera Replacement, Mid-panel: Schritt 3, Bild 1 von 2 LG Tribute Rear-Facing Camera Replacement, Mid-panel: Schritt 3, Bild 2 von 2
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
  4. LG Tribute Rear-Facing Camera Replacement: Schritt 4, Bild 1 von 2 LG Tribute Rear-Facing Camera Replacement: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
  5. LG Tribute Rear-Facing Camera Replacement, Rear Facing Camera: Schritt 5, Bild 1 von 2 LG Tribute Rear-Facing Camera Replacement, Rear Facing Camera: Schritt 5, Bild 2 von 2
    • Disconnect the rear facing camera from the motherboard using a plastic opening tool.
    • Lift the rear facing camera out of its housing.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 629
