Zum Hauptinhalt wechseln
LG Tribute Royal Battery Replacement
Was du brauchst
  1. LG Tribute Royal Battery Replacement, Remove back cover: Schritt 1, Bild 1 von 2 LG Tribute Royal Battery Replacement, Remove back cover: Schritt 1, Bild 2 von 2
    • Use an iopener to open the back panel and remove it...there will be glue...
  2. LG Tribute Royal Battery Replacement, Unscrew the screws: Schritt 2, Bild 1 von 2 LG Tribute Royal Battery Replacement, Unscrew the screws: Schritt 2, Bild 2 von 2
    • Unscrew the screws holding the motherboard cover on...there should be
  3. LG Tribute Royal Battery Replacement, Remove motherboard cover: Schritt 3, Bild 1 von 2 LG Tribute Royal Battery Replacement, Remove motherboard cover: Schritt 3, Bild 2 von 2
    • Remove the motherboard cover and apply adequate pressure because there is some resistance.
  4. LG Tribute Royal Battery Replacement, Remove Old Battery: Schritt 4, Bild 1 von 2 LG Tribute Royal Battery Replacement, Remove Old Battery: Schritt 4, Bild 2 von 2
    • Disconnect the yellow ribbon cable connector that connects the battery to the mother board. Make sure to use plastic to remove the battery and pull up on it to break the glue also pull battery pull tabs correctly.
  5. LG Tribute Royal Battery Replacement, Reconnect New Battery: Schritt 5, Bild 1 von 1
    • Reconnect the new battery by connecting the ribbon cable connector back to the motherboard.
  6. LG Tribute Royal Battery Replacement, Reassemble the phone: Schritt 6, Bild 1 von 2 LG Tribute Royal Battery Replacement, Reassemble the phone: Schritt 6, Bild 2 von 2
    • Repeat steps backwards from step 3 to reassemble the phone.
Abschluss
Rose Schneider
413 Reputation
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 415
