Zum Hauptinhalt wechseln
LG Ultimate 2 Digitizer Replacement
Was du brauchst
  1. LG Ultimate 2 Digitizer Replacement, Battery: Schritt 1, Bild 1 von 1
    • Wedge the plastic opening tool into the seam between the plastic backing and the rest of the phone.
  2. LG Ultimate 2 Digitizer Replacement: Schritt 2, Bild 1 von 1
    • Use your hand to pull the plastic cover completely off of the phone.
  3. LG Ultimate 2 Digitizer Replacement: Schritt 3, Bild 1 von 1
    • Insert the plastic opening tool into the wedge near the bottom of the battery.
    • Lift the battery out.
  4. LG Ultimate 2 Digitizer Replacement, Digitizer: Schritt 4, Bild 1 von 2 LG Ultimate 2 Digitizer Replacement, Digitizer: Schritt 4, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the 11 mid-frame screws.
  5. LG Ultimate 2 Digitizer Replacement: Schritt 5, Bild 1 von 2 LG Ultimate 2 Digitizer Replacement: Schritt 5, Bild 2 von 2
    • Insert the plastic opening tool to start wedging the phone apart.
    • Trace the plastic opening tool along the edge for the entire perimeter of the phone, pulling it apart as you go.
  6. LG Ultimate 2 Digitizer Replacement: Schritt 6, Bild 1 von 1
    • Use a plastic opening tool or fingernail to separate the zip connector.
    • The zip connector does not detach completely from the phone, but acts as a flap.
  7. LG Ultimate 2 Digitizer Replacement: Schritt 7, Bild 1 von 1
    • Insert the plastic opening tool between the screen and the base. This may be difficult because of the adhesive, but enough leverage should force an opening.
  8. LG Ultimate 2 Digitizer Replacement: Schritt 8, Bild 1 von 1
    • Continue moving the plastic opening tool along the edge of the screen, separating the pieces from the adhesive.
    • A hair dryer might be useful to help melt the adhesive.
  9. LG Ultimate 2 Digitizer Replacement: Schritt 9, Bild 1 von 1
    • Pry the screen off after all pieces have been loosened from the adhesive.
Abschluss
IUPUI, Team S5-G2, Baechle Spring 2018 Mitglied von IUPUI, Team S5-G2, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G2
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 377
