Zum Hauptinhalt wechseln
LG V10 Battery Replacement
Was du brauchst
  1. LG V10 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Wedge the flat end of the plastic spudger, or the tip of your finger, in between the back cover and the LG V10’s charging port.
    • If using a spudger, it should not be in the charging port, but between the metal lining of the charging port and the back cover.
    • Carefully lift up on the spudger or with your finger so that the back cover pops up. The rest of the back cover should easily come off by sliding a finger or spudger under the back cover and around the sides.
  2. LG V10 Battery Replacement: Schritt 2, Bild 1 von 2 LG V10 Battery Replacement: Schritt 2, Bild 2 von 2
    • There’s an impression next to the battery for the user to use their finger to pry the battery out; pry the battery out using your finger or the flat end of the spudger.
Abschluss
After replacing the old battery with a new one, reattach the back cover and press down on all sides to make sure it's properly reattached.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Nikolai Lesh
344 Reputation
1 Anleitung geschrieben
Master Techs Mitglied von Master Techs
Community
311 Mitglieder
1.196 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 17
Insgesamt: 2,797
