Zum Hauptinhalt wechseln
LG V30 Plus Rear Glass Replacement
Was du brauchst
  1. LG V30 Plus Rear Glass Replacement, Rear Glass: Schritt 1, Bild 1 von 1
    • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
    • Allow to sit for 1-2 minutes to heat up the adhesive.
    • A heat gun may need to be used if you have trouble separating the backing in the next step.
  2. LG V30 Plus Rear Glass Replacement: Schritt 2, Bild 1 von 2 LG V30 Plus Rear Glass Replacement: Schritt 2, Bild 2 von 2
    • Insert an Opening Tool into the seam between the rear glass and side of the phone.
    • Pry the glass off just enough to insert an Opening Pick.
    • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
  3. LG V30 Plus Rear Glass Replacement: Schritt 3, Bild 1 von 1
    • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
Abschluss
Cal Poly, Team S1-G3, Maness Spring 2019 Mitglied von Cal Poly, Team S1-G3, Maness Spring 2019
CPSU-MANESS-S19S1G3
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 1,054
