Zum Hauptinhalt wechseln
LG VX3100 Keypad Replacement
Was du brauchst
  1. LG VX3100 Keypad Replacement, Battery: Schritt 1, Bild 1 von 2 LG VX3100 Keypad Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn off the cellphone by pressing down on the red "END" button for 3 seconds.
    • Flip cellphone over and press up on the gray sliding mechanism towards the top of the phone. At the same time, pull on the large silver battery and it should come right off.
    Frag FixBot
  2. LG VX3100 Keypad Replacement, Keypad: Schritt 2, Bild 1 von 1
    • Use a T7 Torx screwdriver to remove the four screws that are located underneath the area where the battery was.
    Frag FixBot
  3. LG VX3100 Keypad Replacement: Schritt 3, Bild 1 von 3 LG VX3100 Keypad Replacement: Schritt 3, Bild 2 von 3 LG VX3100 Keypad Replacement: Schritt 3, Bild 3 von 3
    • Be careful when removing the casing as the spudger can damage the plastic cover of the phone.
    • Use the spudger to carefully pry around the sides of the plastic casing and remove the back side of the phone.
    Frag FixBot
  4. LG VX3100 Keypad Replacement: Schritt 4, Bild 1 von 3 LG VX3100 Keypad Replacement: Schritt 4, Bild 2 von 3 LG VX3100 Keypad Replacement: Schritt 4, Bild 3 von 3
    • Use the spudger to remove the back side of the phone.
    • The logic board is still connected to the rest of the phone with a gold strip; be careful when removing the board.
    • Use the spudger to gently push the keypad out from the other side of the phone.
    Frag FixBot
Abschluss
Cal Poly, Team 34-58, Forte Spring 2010 Mitglied von Cal Poly, Team 34-58, Forte Spring 2010
CPSU-FORTE-S10S34G58
5 Mitglieder
9 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 49
Insgesamt: 2,649
