Zum Hauptinhalt wechseln
Einleitung
This guide will show you how to replace the antenna.
Werkzeuge
Keine Werkzeuge angegeben.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Push the light gray rectangle in the top-center up. While pushing up grab the sides of the battery and pull out. While pushing up grab the sides of the battery and pull out.
    • Push the light gray rectangle in the top-center up.
    • While pushing up grab the sides of the battery and pull out.
  2. Unscrew the antenna by grasping the base and twisting counterclockwise.
    • Unscrew the antenna by grasping the base and twisting counterclockwise.
    • The antenna may separate from a black sleeve during removal. You may need to use tweezers to remove the sleeve. Remove both the antenna and the sleeve and set aside.
Ziellinie
Nico Chiarito
22 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 8-47, Regan Winter 2010 Mitglied von Cal Poly, Team 8-47, Regan Winter 2010
CPSU-REGAN-W10S8G47
5 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,287
