Was du brauchst
Press the light grey button in the top-center on the back of the phone.
While pressing, slide the battery and cover up.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Unscrew the antenna by grasping the base and twisting counterclockwise.
The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside.
With the phone flipped open, wedge the back cover from the faceplate by running the tip of the plastic opening tool around the seam on the back of the phone.
Gently pull the two pieces apart to separate, and set the back casing aside.
<b>To reassemble your device, follow these instructions in reverse order.</b>
