Zum Hauptinhalt wechseln
LG VX4500 display interconnect cable
Was du brauchst
  1. LG VX4500 display interconnect cable, Battery: Schritt 1, Bild 1 von 1
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. LG VX4500 display interconnect cable: Schritt 2, Bild 1 von 2 LG VX4500 display interconnect cable: Schritt 2, Bild 2 von 2
    • Now just lift up on the battery and remove it from the phone.
  3. LG VX4500 display interconnect cable, Rear Cover: Schritt 3, Bild 1 von 1
    • Remove the rubber grommet using a Spudger.
  4. LG VX4500 display interconnect cable: Schritt 4, Bild 1 von 1
    • Be sure not to lose the screws. They are small!
    • Remove the five screws using a Phillips #00 Screwdriver.
  5. LG VX4500 display interconnect cable: Schritt 5, Bild 1 von 3 LG VX4500 display interconnect cable: Schritt 5, Bild 2 von 3 LG VX4500 display interconnect cable: Schritt 5, Bild 3 von 3
    • When removing back cover, be careful not to break the speaker wires.
    • Using an Opening Tool, carefully pry off the back cover.
    • Using tweezers, gently pull the speaker wires out.
  6. LG VX4500 display interconnect cable: Schritt 6, Bild 1 von 1
    • Separate the two halves.
  7. LG VX4500 display interconnect cable, Keypad: Schritt 7, Bild 1 von 3 LG VX4500 display interconnect cable, Keypad: Schritt 7, Bild 2 von 3 LG VX4500 display interconnect cable, Keypad: Schritt 7, Bild 3 von 3
    • Carefully pry and lift up on the logic board using an iPod Opening Tool.
  8. LG VX4500 display interconnect cable: Schritt 8, Bild 1 von 1
    • Carefully flip the logic board up and out of the way.
  9. LG VX4500 display interconnect cable: Schritt 9, Bild 1 von 3 LG VX4500 display interconnect cable: Schritt 9, Bild 2 von 3 LG VX4500 display interconnect cable: Schritt 9, Bild 3 von 3
    • Use an iPod Opening Tool to lift up on the keypad and pull it out.
  10. LG VX4500 display interconnect cable, Motherboard: Schritt 10, Bild 1 von 1
    • DO NOT TOUCH SOLDERING IRON. IT IS EXTREMELY HOT.
    • Use a soldering iron to desolder the solder joint on the front of the motherboard.
    • If you need more information on soldering, refer to this guide.
  11. LG VX4500 display interconnect cable: Schritt 11, Bild 1 von 1
    • Desolder the joint on the back using a soldering iron.
  12. LG VX4500 display interconnect cable: Schritt 12, Bild 1 von 3 LG VX4500 display interconnect cable: Schritt 12, Bild 2 von 3 LG VX4500 display interconnect cable: Schritt 12, Bild 3 von 3
    • Carefully detach the ribbon cable and remove the motherboard.
  13. LG VX4500 display interconnect cable, Outer Display Cover: Schritt 13, Bild 1 von 1
    • Remove 4 rubber grommets using the Spudger.
  14. LG VX4500 display interconnect cable: Schritt 14, Bild 1 von 1
    • Remove 4 screws using the Phillips #00 Screwdriver.
  15. LG VX4500 display interconnect cable: Schritt 15, Bild 1 von 3 LG VX4500 display interconnect cable: Schritt 15, Bild 2 von 3 LG VX4500 display interconnect cable: Schritt 15, Bild 3 von 3
    • Carefully pry off outer cover using iPod Opening Tool.
  16. LG VX4500 display interconnect cable, Display: Schritt 16, Bild 1 von 2 LG VX4500 display interconnect cable, Display: Schritt 16, Bild 2 von 2
    • Remove speaker using the Spudger.
  17. LG VX4500 display interconnect cable: Schritt 17, Bild 1 von 2 LG VX4500 display interconnect cable: Schritt 17, Bild 2 von 2
    • Remove vibrator using the Spudger.
  18. LG VX4500 display interconnect cable: Schritt 18, Bild 1 von 2 LG VX4500 display interconnect cable: Schritt 18, Bild 2 von 2
    • Lift up LCD display using iPod Opening Tool.
  19. LG VX4500 display interconnect cable: Schritt 19, Bild 1 von 1
    • DO NOT TOUCH THE SOLDERING IRON. IT IS EXTREMELY HOT!
    • De-solder solder joint using Soldering Iron.
  20. LG VX4500 display interconnect cable: Schritt 20, Bild 1 von 2 LG VX4500 display interconnect cable: Schritt 20, Bild 2 von 2
    • Pry off ribbon cable using iPod Opening Tool.
  21. LG VX4500 display interconnect cable, Ribbon Cable: Schritt 21, Bild 1 von 3 LG VX4500 display interconnect cable, Ribbon Cable: Schritt 21, Bild 2 von 3 LG VX4500 display interconnect cable, Ribbon Cable: Schritt 21, Bild 3 von 3
    • Turn phone so that the back side is facing you.
    • Press blue button and remove top half using Spudger.
  22. LG VX4500 display interconnect cable: Schritt 22, Bild 1 von 2 LG VX4500 display interconnect cable: Schritt 22, Bild 2 von 2
    • Remove cable from bottom section.
Abschluss
Cal Poly, Team 25-88, Amido Spring 2010 Mitglied von Cal Poly, Team 25-88, Amido Spring 2010
CPSU-AMIDO-S10S25G88
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 3,179
