Einleitung
Replacing the ribbon cable.
Was du brauchst
Turn the closed phone so that the back panel is facing you.
Press down and forward firmly on the gray tab in the middle of the phone.
Using an Opening Tool, carefully pry off the back cover.
Using tweezers, gently pull the speaker wires out.
Carefully pry and lift up on the logic board using an iPod Opening Tool.
Use a soldering iron to desolder the solder joint on the front of the motherboard.
Turn phone so that the back side is facing you.
Press blue button and remove top half using Spudger.
