Einleitung
To repair or replace the keyboard on your LG VX4500 cell phone, consult this guide.
Was du brauchst
To remove the battery from your LG VX4500, turn the phone so that the back panel is showing.
Using a paper clip, remove all 4 rubber screwcaps from the screw ports.
With a Phillips head screwdriver, remove all 4 screws from their ports.
Also remove the rubber screwcap in the upper part of the back panel along with the screw under it.
The fifth screw will be more difficult to get out because the plastic port has much higher sides.
Run a plastic opening tool along the seam to seperate the keyboard cover and the back panel
Remove the back panel, now the logic board, keyboard and microphone are exposed.
With your fingers, gently lift up the gold connector until it is completely disconnected.
Move the logic board out of the way to reveal the keyboard underneath.
