Zum Hauptinhalt wechseln
Einleitung
This guide illustrates how to replace the LG VX5300 keypad.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Carefully slide battery cover off in a downward direction. Using the plastic opening tool, remove the battery. Light force may be necessary. Using the plastic opening tool, remove the battery. Light force may be necessary.
    • Carefully slide battery cover off in a downward direction.
    • Using the plastic opening tool, remove the battery. Light force may be necessary.
  2. Using a Phillips #0 screwdriver, remove the five screws from the back cover and carefully set them aside.
    • Using a Phillips #0 screwdriver, remove the five screws from the back cover and carefully set them aside.
  3. Using the plastic opening tool, carefully lift the back cover off.
    • Using the plastic opening tool, carefully lift the back cover off.
  4. Before touching anything inside the phone: it is crucial that you are very cautious when working around the wiring and sensor bars. Look to the following photo for the location of the two sensor bars.
    • Before touching anything inside the phone: it is crucial that you are very cautious when working around the wiring and sensor bars.
    • Look to the following photo for the location of the two sensor bars.
    • Without disconnecting the orange wire, carefully flip the computer chip over and lay flat on the table, exposing the keypad.
  5. Carefully remove the keypad and replace with the new keypad. If sensor bars behind the volume and camera buttons fall out, gently put them back in place behind the buttons.
    • Carefully remove the keypad and replace with the new keypad.
    • If sensor bars behind the volume and camera buttons fall out, gently put them back in place behind the buttons.
  6. Carefully set the computer chip back in place.
    • Carefully set the computer chip back in place.
  7. Place the back cover back on and secure it with the screws. Place the back cover back on and secure it with the screws.
    • Place the back cover back on and secure it with the screws.
  8. Insert the battery. Slide the back cover on the phone.
    • Insert the battery.
    • Slide the back cover on the phone.
Ziellinie
Ashley
9 Reputation
3 Anleitungen geschrieben
Ohio State, Team 1-1, Buehl Spring 2013 Mitglied von Ohio State, Team 1-1, Buehl Spring 2013
OSU-BUEHL-S13S1G1
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 475
