Zum Hauptinhalt wechseln
Einleitung
This guide requires very little disassembly to complete.
  1. Hold your phone with the back casing facing you and the bottom of the phone towards the sky. Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
    • Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
    • Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  3. Insert your finger into the small indentation above the battery. Push down on the battery and pull it away from the phone; it will pop out.
    • Insert your finger into the small indentation above the battery.
    • Push down on the battery and pull it away from the phone; it will pop out.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Irena Tran
435 Reputation
4 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 490
