Zum Hauptinhalt wechseln
Einleitung
This guide is for dismantling the body of the LG VX6000, a step that is required for many other repairs
Ersatzteile
Keine Ersatzteile angegeben.
  1. Locate the dark gray tab on the back of the phone towards the top. Push the tab towards the top of the phone to release the battery.
    • Locate the dark gray tab on the back of the phone towards the top. Push the tab towards the top of the phone to release the battery.
  2. Remove the battery by lifting up and rotating the battery away from the bottom edge.
    • Remove the battery by lifting up and rotating the battery away from the bottom edge.
  3. Pull out the two rubber cushions located on the top of the phone using tweezers.
    • Pull out the two rubber cushions located on the top of the phone using tweezers.
    • Only remove the two cushions that are circled!
  4. Unscrew the six screws seen on the back using a Phillips 00 Screwdriver.
    • Unscrew the six screws seen on the back using a Phillips 00 Screwdriver.
    • Remove screws and carefully place on an uncluttered surface or in a small container.
  5. Carefully remove the back of the phone gently using your fingernails or tweezers.
    • Carefully remove the back of the phone gently using your fingernails or tweezers.
    • There are a pair of red and blue wires that plugs into the motherboard. These wires will snap if you force the pieces apart.
    • To reattach the back, you must plug these wires back in.
Ziellinie
Cal Poly, Team 4-11, Forte Winter 2010 Mitglied von Cal Poly, Team 4-11, Forte Winter 2010
CPSU-FORTE-W10S4G11
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 2,052
