Einleitung
This guide is for dismantling the body of the LG VX6000, a step that is required for many other repairs
Was du brauchst
Locate the dark gray tab on the back of the phone towards the top. Push the tab towards the top of the phone to release the battery.
Pull out the two rubber cushions located on the top of the phone using tweezers.
Unscrew the six screws seen on the back using a Phillips 00 Screwdriver.
Remove screws and carefully place on an uncluttered surface or in a small container.
Carefully remove the back of the phone gently using your fingernails or tweezers.
Fast fertig!
Ziellinie
