Zum Hauptinhalt wechseln
Einleitung
This guide is designed to remove or replace the logic board of the LG VX6000.
  1. Locate the dark gray tab on the back of the phone towards the top. Push the tab towards the top of the phone to release the battery.
    • Locate the dark gray tab on the back of the phone towards the top. Push the tab towards the top of the phone to release the battery.
  2. Remove the battery by lifting up and rotating the battery away from the bottom edge.
    • Remove the battery by lifting up and rotating the battery away from the bottom edge.
  3. Pull out the two rubber cushions located on the top of the phone using tweezers.
    • Pull out the two rubber cushions located on the top of the phone using tweezers.
    • Only remove the two cushions that are circled!
  4. Unscrew the six screws seen on the back using a Phillips 00 Screwdriver.
    • Unscrew the six screws seen on the back using a Phillips 00 Screwdriver.
    • Remove screws and carefully place on an uncluttered surface or in a small container.
  5. Carefully remove the back of the phone gently using your fingernails or tweezers.
    • Carefully remove the back of the phone gently using your fingernails or tweezers.
    • There are a pair of red and blue wires that plugs into the motherboard. These wires will snap if you force the pieces apart.
    • To reattach the back, you must plug these wires back in.
  6. Carefully peel off the adhesive tab as shown in the photo
    • Carefully peel off the adhesive tab as shown in the photo
    • The tab should not fully separate from the phone.
  7. Locate the yellow connection towards the top of the phone. This is directly connected to the screen. Remove the connector by carefully prying it away from the motherboard and lifting it away from the phone
    • Locate the yellow connection towards the top of the phone. This is directly connected to the screen.
    • Remove the connector by carefully prying it away from the motherboard and lifting it away from the phone
    • Do not pull too hard on the connector.
  8. Gently lift a corner of the motherboard away from the casing to remove.
    • Gently lift a corner of the motherboard away from the casing to remove.
Abschluss
Adam Altman
1 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 4-11, Forte Winter 2010 Mitglied von Cal Poly, Team 4-11, Forte Winter 2010
CPSU-FORTE-W10S4G11
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 3,086
