Zum Hauptinhalt wechseln
LG VX6100 Front Case Replacement
Was du brauchst
  1. LG VX6100 Front Case Replacement, Front Case: Schritt 1, Bild 1 von 1
    • Remove the four grey plugs using either tweezers or a push pin.
  2. LG VX6100 Front Case Replacement: Schritt 2, Bild 1 von 1
    • Remove the four screws that are now exposed using a Phillips #00 screwdriver.
    • Be sure to put the screws in a safe place as they are very small and easy to lose.
  3. LG VX6100 Front Case Replacement: Schritt 3, Bild 1 von 1
    • Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
    • Insert the opener tool into the seem between the case and the phone. Apply pressure to separate the two pieces.
    • Do this across the entire length of the seem until the case is no longer attached to the phone.
  4. LG VX6100 Front Case Replacement: Schritt 4, Bild 1 von 1
    • The case can now be removed and the interior of the front is accessible.
Abschluss
Ryan Bishop
1 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 12-39, Regan Spring 2012 Mitglied von Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 765
