Zum Hauptinhalt wechseln
LG VX6100 Keypad Replacement
Was du brauchst
  1. LG VX6100 Keypad Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Push down on the gray "PUSH" button on the back side of the phone.
    • Slide the back case downward. Then, lift and remove the case.
  2. LG VX6100 Keypad Replacement: Schritt 2, Bild 1 von 1
    • Lift up on the battery to remove it from the case.
  3. LG VX6100 Keypad Replacement: Schritt 3, Bild 1 von 1
    • Use a push-pin or tweezers to pry both of the tear-shaped screw covers out of the top of the phone.
  4. LG VX6100 Keypad Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #00 screwdriver to unscrew the six case screws from the back of the phone.
  5. LG VX6100 Keypad Replacement: Schritt 5, Bild 1 von 2 LG VX6100 Keypad Replacement: Schritt 5, Bild 2 von 2
    • Insert a plastic opener tool through the seam between the back case and the rest of the phone.
    • Slowly slide the tool along the seam. Lift up on the back case while you do this until the back case comes apart.
  6. LG VX6100 Keypad Replacement, Keypad: Schritt 6, Bild 1 von 1
    • Lift the bottom of the logic board out of the case.
    • Make sure not to lift the top of the logic board, since it is still connected to the backcase of the phone.
  7. LG VX6100 Keypad Replacement: Schritt 7, Bild 1 von 1
    • Gently lift up on any edge of the white keypad to remove it from the phone case.
Abschluss
Teal
1 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 12-39, Regan Spring 2012 Mitglied von Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 538
