Zum Hauptinhalt wechseln
LG VX6100 Speaker Replacement
Was du brauchst
  1. LG VX6100 Speaker Replacement, Front Case: Schritt 1, Bild 1 von 1
    • Remove the four grey plugs using either tweezers or a push pin.
  2. LG VX6100 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove the four screws that are now exposed using a Phillips #00 screwdriver.
    • Be sure to put the screws in a safe place as they are very small and easy to lose.
  3. LG VX6100 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
    • Insert the opener tool into the seem between the case and the phone. Apply pressure to separate the two pieces.
    • Do this across the entire length of the seem until the case is no longer attached to the phone.
  4. LG VX6100 Speaker Replacement: Schritt 4, Bild 1 von 1
    • The case can now be removed and the interior of the front is accessible.
  5. LG VX6100 Speaker Replacement, Speaker: Schritt 5, Bild 1 von 2 LG VX6100 Speaker Replacement, Speaker: Schritt 5, Bild 2 von 2
    • Locate the four solder joints (connected to the yellow, black, blue, and red wires) on the bottom part of the phone, connected to the speaker. It will appear as a black circular part with some holes in it.
    • Place a piece of solder wick on top of the solders.
    • Very carefully, place the tip of the soldering iron on top of the solder wick. Hold it steady until the solder is soaked up into the solder wick.
    • Soldering iron will damage circuitry if held down for too long.
    • Cut off the used solder wick with pliers and repeat this step if any solder remains.
  6. LG VX6100 Speaker Replacement: Schritt 6, Bild 1 von 1
    • After the solder has been removed, pry out the speaker with the plastic opening tool.
Abschluss
Ryan Bishop
1 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 12-39, Regan Spring 2012 Mitglied von Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 512
