Einleitung
Phone won't charge, and the charger is functional? Replace your phone's charging adapter.
NOTE: Charging adapter is attached to the logic board, so replacement requires replacing the logic board.
Was du brauchst
Lay the phone, screen side down, in your palm.
Slide the grey button towards the top of the phone.
With the button unlocked, grab the battery on the sides and pull up, then slide the battery up to completely remove it from the phone.
Unsnap the gold rectangular connector and silver square connector from the motherboard.
Remove the motherboard. Do not remove other components.
Insert the new motherboard with the white side facing down.
