Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Einleitung
Sat on your phone and cracked the outer screen? Replace it.
NOTE: Replacing the outer screen requires replacing the entire outer casing.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using Tweezers, remove 4 rubber screw covers.
    • Using Tweezers, remove 4 rubber screw covers.
    • Remove screws located under rubber plugs using the screwdriver by turning counterclockwise.
    • NOTE: Screws will not come completely out of phone.
  2. Using the iPod Opening Tool, pry the face plate off the front of the phone.
    • Using the iPod Opening Tool, pry the face plate off the front of the phone.
    • NOTE: There will be a significant amount of resistance to removing the face plate from the phone.
    • Align new face plate where cracked face plate perviously was.
Abschluss
Nichole Shaw
1 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 18-75, Johann Spring 2010 Mitglied von Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
4 Mitglieder
14 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 1,578
