Zum Hauptinhalt wechseln
LG VX7000 Internal LCD Screen Replacement
Was du brauchst
  1. LG VX7000 Internal LCD Screen Replacement, Internal LCD Screen: Schritt 1, Bild 1 von 1
    • Using Tweezers, remove 4 rubber screw covers.
    • Remove screws located under rubber plugs using the screwdriver by turning counterclockwise.
    • NOTE: Screws will not come completely out of phone.
  2. LG VX7000 Internal LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Using the iPod Opening Tool, pry the face plate off the front of the phone.
    • NOTE: There will be a significant amount of resistance to removing the face plate from the phone.
  3. LG VX7000 Internal LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Unsnap gold plate from the secondary logic board.
    • Reposition the plate so that it is out of the way for face plate removal.
  4. LG VX7000 Internal LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Twist upper half of face plate in order to release it from the hinge.
    • Using tweezers detach the speaker and the secondary battery from the faceplate, leaving wires attached.
  5. LG VX7000 Internal LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Align new face plate in correct orientation in order to install.
Abschluss
Nichole Shaw
1 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 18-75, Johann Spring 2010 Mitglied von Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 2,219
