Einleitung
Replace a cracked internal LCD display.
Note: to replace the internal display, you must replace the entire face plate, not just the plastic screen.
Was du brauchst
Using Tweezers, remove 4 rubber screw covers.
Remove screws located under rubber plugs using the screwdriver by turning counterclockwise.
Unsnap gold plate from the secondary logic board.
Reposition the plate so that it is out of the way for face plate removal.
Twist upper half of face plate in order to release it from the hinge.
Using tweezers detach the speaker and the secondary battery from the faceplate, leaving wires attached.
